Weld in LCA relocation bracket inputs
Old Nov 10, 2017 | 11:59 PM
FCar2000TA's Avatar
Veteran: Air Force
Default Weld in LCA relocation bracket inputs
Along with the mini-tub and coil-overs, I am going to get some weld in LCA relocation brackets. Is there any benefit to one company over the other? I notice that the UMI one has more mounts for the LCA than the Spohn or BMR ones.
Old Nov 14, 2017 | 12:52 PM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
Honestly, LCA relocation brackets will have no real effect with the mini-tub. They all use the stock location mounting position for the LCA. However some arms like our MTCA003 have offset spacers to bring the arm in to the inner most part of the stock mounting locations for tire clearance. You can easily fit up to a 325 with stock arm locations and an offset LCA like this. The amount of holes adds adjustability for instant center and anti-squat percentage which can also be change with torque arm mounting position
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
