How to reconnect ABS?
Whilst having my morning breakfast of way too much food and discussions with my father about my car, we crawled onto the topic of ABS and whether or not it's worth it. We both agree that it's good to know how to handle a car without it, but it's better to have a car with it.
On to my question. The previous owner of my car(I will refer to him as "Moron" from here) disconnected the ABS system in the car. Now, Moron must have been of the mindset that 'deleting' meant exactly that, in which case he went through everything that he deemed nonessential with a pair of wire cutters. Instead of simply disconnecting the ABS module, he went through the trouble of doing some weight reduction and cutting the connector. He also did this for traction control, A/C, cruise control, emissions gear, and a few other bits and bobs.
Now the cruise and traction controls I can live without, emissions aren't really in the cards, and I can cope without the A/C. But because I am not completely crazy, I would like to get my ABS back. Is there any sort of GM diagram on the module, along with part numbers and wire colors I could use to figure out how to rewire it? I am currently trying to build my car to be an all around fast car, and my brakes are part of the deal. If it is too expensive to replace the harness, or too intensive, I would consider an aftermarket unit, if anyone has experience with them in an f-body.
Thank you for your help!
How much did the original owner cut? There are 4 connectors on the ABS block (1 for power, 3 for the motors), plus the throttle servo over the valve cover if you have TCS, then the EBCM/EBTCM under the dash. Then there will be a separate motor block under the ABS block if you have traction control.
The easiest way is to check your RPO sticker for NW9, which is the traction control option. You should also have a button for it on your center console.
I stand corrected, thanks for the info!!
Also, what would be a good rear brake upgrade? I intend to take this car to HPDE events and really don't want to run out of brakes, so I'm looking into the best setup for heat dissipation I can find.
