Torque arm
Old Dec 1, 2017 | 10:51 AM
qweedqwag's Avatar
Default Torque arm
Guys, I've searched without luck, are there any bushings on the rear of the torque are that attached to the rear end or are the bolts just tightened to the arm? Got a clunking going on while crusing at part throttle, just trying to eliminate one thing at a time.
Mike.
Old Dec 1, 2017 | 11:03 AM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
No, the arm bolts solid to the axle. I have seen those bolts work their way loose and cause clunking and vibration however. I would recommend checking the torque on them
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old Dec 1, 2017 | 11:08 AM
98CayenneT/A's Avatar
Check the tranny mount also if its origins stock rubber mount.
Old Dec 1, 2017 | 11:25 AM
qweedqwag's Avatar
Thanks guys I'll check them both, appreciate the help.
Mike.
Old Dec 1, 2017 | 11:33 AM
someblackguy224's Avatar
offering up some advice! i would loc-tite the bolts, mine came loose experienced the same clunking. just an F.Y.I but you have to hold the top of the bolt in order to tighten the nut correctly, add Blue loc-tite THO i cant stress that enough anything supension related BLUE LOC-TIT!! happy RAACING! :secret2 :
