MCW subframe connectors
Old Sep 13, 2018 | 08:21 PM
PARMY's Avatar
Default MCW subframe connectors
Hey Guys, I just purchased a set of MWC subframe connectors from a member on here and was just on their sight and it mentioned slight massaging for clearance...can anyone with these SFC elaborate and possibly show pics?
Old Sep 13, 2018 | 08:40 PM
Floorman279's Avatar
mine needed no massaging
Old Sep 14, 2018 | 08:21 AM
mikedamageinc's Avatar
The only massaging mine needed were the front rails were bent from years of repeatedly jacking and bending. I added some tabs to get more contact. Also I bent the fuel and brake lines a little to keep away from rubbing. The more you weld on them the more you will notice too.
Old Sep 15, 2018 | 08:28 AM
scj's Avatar
scj
My front rails were the same as mentioned as above. Bent from years of jacking. I got them as straight as I could. The rear floor pan touches mine but didn’t really need to be massaged. I could probably weld them here also, but I didn’t feel like pulling carpet out of the way and such. Just welding the front and rear really made a huge difference. And I went from a set of 3pt UMI connectors. Not that the UMI stuff wasn’t good, they worked well, but mwc mice made a bigger difference in feel imo.
