Phasing steering shaft
Old Dec 6, 2018 | 08:52 PM
BBButch's Avatar
Default Phasing steering shaft
I have 57 Chevy LS3, Jim Meyers racing front end.
I know that you have to phase steering U joints. I am changing one to a double u joint because of a tight angle.
So I got a Uni-Steer 8050910 double U Joint & was going to use my lower Framing River FR1759DD . the problem is that the Ujoints are out of phase.
I guess because of the two different brands of U joints.
Has anybody run into this?
Will it be OK ,or can I use them since I am using a double U joint & support bearing?
