Belltech Sway Bars
Old Mar 22, 2019 | 03:32 PM
09 Rooster's Avatar
formerly 04 Rooster (2013-12-10)
Default Belltech Sway Bars
Anyone using these? Belltech Kit 9980. I searched and couldn't find anything on them. I am thinking about upgrading my sway bars to go along with my Strano springs and Koni's. I have upgraded trailing arms, torque arms and panhard bar. This is my daily driver in the summer and I'd like it to handle a bit better. No track time or drag racing in my future.
The belltech kit caught my eye as it is $150 cheaper than the next cheapest set...and yes that is why I am asking here (too good to be true and all). Also, I am in Canada so that $150 cheaper is about $200 cheaper in Canadian dollars.
The Belltech bars are solid 35 mm and 25 mm so I am wondering if the rear bar will be too stiff versus the other options.
Old Mar 23, 2019 | 11:10 AM
JD_AMG's Avatar
25mm rear bar would be way too stiff(oversteer), not to mention really heavy compared to a proper 22mm hollow bar that you should be using with 35mm front for neutral balance.
Old Mar 23, 2019 | 01:31 PM
09 Rooster's Avatar
That makes a lot of sense. Thanks
I see Dorman makes a 22mm bar that is a pretty good price. I might try that. I couldn’t find any info on it either. I normally upgrade to poly bushings and metal end links so I think I’ll do that on the front and look to add a 22mm on the back.
Old Mar 23, 2019 | 04:45 PM
bad_408_vert's Avatar
Finding used good shape known brand parts is also a good way to go. Avoids hassle of re doing the mod.
my .02
Old Mar 23, 2019 | 08:16 PM
09 Rooster's Avatar
Cheers man but no one in the for sale section wants to ship to Canada 🙁
I always check for used though 👍
Old Mar 30, 2019 | 06:24 PM
LilJayV10's Avatar
Use Strano bars and be done with it.
