Spohn adj. Front upper control arms
Many here would suggest Strano....BMR or UMI springs
I have not used any of those so cant give you a review
I don't know why you are having the UCA hit because the jounce bumper on the shock should prevent this from happening. These could be ruined or missing. Either that or Spohn designed these bad and the car can now bottom out on them instead of the jounce bumper. Then the only way to help this be less likely to occur is to replace the springs which would raise the car some and be a higher rate, like one of the 3 mentioned above. I'm preferential to UMI, though I have no experience with their springs. I had H&R springs which were fine and now UMI coilovers.
Hope that helps.
