Brake Problems
Old May 9, 2019 | 10:06 AM
FamousZ's Avatar
Default Brake Problems
I recently had pulled my engine and reinstalled it along with ctsV front brakes and stainless lines, as well has had rear off for powder coating. I went through and bled all the brakes and still the pedal went to the floor. So I was told to try a new master, I bench bled it and installed and rebled the brakes and still nothing. So I tried a tech 2 to cycle the abs and still the pedal hits the floor. I don’t know what to do.
2000 Camaro Z28
Old May 10, 2019 | 02:19 PM
eb110americana's Avatar
Pump the brakes. Does the pedal firm up?
When the pedal is down, do the brakes hold the car? Can any of the individual wheels turn?
When you bled the brakes, did fluid come out in a clean stream from each bleeder?
Are your new front brakes installed with the bleeder screws at the top?
Check for leaks anywhere under the car, especially at junctions of the hard and soft lines.
Is your intake vacuum abnormally high?
Is the booster/master cylinder assembly bolted flush to the firewall and to each other?
Might you have lost or left out the large center pin from the back of the booster, which engages the master cylinder?
