Power steering leak
89.9% probability - You have a power steering cooler and it's leaking. That P/S fluid is being driven (high pressure to lower pressure) into your coolant system. Check for the stock P/S cooler. (The rack return line goes through the cooler, which is inline to one of the radiator hoses.) If you have this setup, check the coolant dipstick for alien-like slime from this effect. This thread is for our refugees impacted by this common problem: https://ls1tech.com/forums/general-m...g-success.html
5% probability - Your P/S fluid is really dirty and is boiling over and out of the reservoir.
5% probability - You have a P/S pump leak that is ejecting fluid out the shaft seal under the higher RPM.
0.1% probability - Some low-life is siphoning off your fluid.
That thread I linked above also has great information about cooler replacements. If you do a P/S fluid flush and keep on top of that and don't race the car - you probably don't need a cooler at all and can just remove the whole thing.
