Spring measurements
Old Nov 4, 2019 | 11:16 AM
InfernoTA's Avatar
Default Spring measurements
I have a 98 firebird. I need the measurements of the top diameter(inside and out mainly outside)of a rear spring on the suspension. If anyone has one lying around and could measure it for me. I would gently appreciate it.
Thank you
Old Nov 6, 2019 | 07:18 AM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
Don't have springs but the dimensions of the upper spring rubber isolator should do.
Inside diameter of 4 1/8 to accept a 4 1/4" ID spring.
Outside diameter of 5 1/2 to accept a 5 3/8" OD spring.
