Extended Wheel Studs
I have 1/4" spacers on the rear of my 2000 Firebird. I'd like to change out the studs for longer ones. I will not be using ARP.
I am trying to find these parts locally (Edmonton, Canada) and Napa says the OEM replacement stud is Napa part number 6411621. They also advise the extended stud (about 1/2" longer) is Napa part number 6411581.
can anyone out there advise if 6411581 is the right stud to use?
The main issue i'm having is dealing with the knurl measurement. I read that OEM is .509" yet the Napa parts have different measurements. the replacement (6411621) knurl is .501" and the longer stud (6411581) is .504"
Will 6411581 work? Is there a different option (other than the expensive ARP)?
thanks and be safe out there!
