Torque Arm install
Old Apr 9, 2020 | 10:57 PM
green28's Avatar
Default Torque Arm install
I have a Midwest Chassis tunnel mount torque arm, a pinon angle finder, and access to a lift. Anything special I need to know or tips on the install, or is it pretty straight forward? Do I need to have the chassis loaded when bolting everything down?
Old Apr 10, 2020 | 08:11 AM
MidwestChassis2's Avatar
It is pretty straight forward for an install. Do not lose the factory crossmember bolts nor the bolts for the torque arm that mount it to the housing as they are reused. If you have a five hole pivot link then start with the center hole and set your pinion angle to -1.5. If the pivot link is not straight up and down do not worry it is fine with a little bit of angle in either direction.
Any questions feel free to give us a call. (309)382-6252
