Steering column
Old Apr 12, 2020 | 05:23 PM
Deguila's Avatar
Default Steering column
Car took a front end hit, steering column hanging off brackets. Was told that column compresses under impact, can it be repaired? 2007 Monte SS. Thanks!
Old Apr 14, 2020 | 10:54 AM
sjsingle1's Avatar
there is a plastic pin that is designed to shear and allow collapse in the shaft........so I would say no
if i am wrong someone correct me
Old Apr 14, 2020 | 11:14 AM
Deguila's Avatar
Thanks for the response. Huh, probably should replace column then. Weird it doesn't seem to be malfunctioning, just doesn't fit back onto mount under the dash. Wasn't that big of a hit, airbags still intact.
Old Apr 14, 2020 | 11:42 AM
Deguila's Avatar
Ive got access to 2006 donor car, so will probably pull column from that. Was trying to not have to mess with pulling ignition and swapping. Plus, Gives me a chance to learn how it works.
