Power steering pump melted
Old Aug 14, 2020 | 12:23 PM
sjsingle1's Avatar
what he said !
Old Aug 14, 2020 | 04:14 PM
blkbowtie98's Avatar
Originally Posted by steering_experts1
Hey @blkbowtie98
We actually do have F-body pumps available. We just updated the pump style, so the products aren't quite ready for online orders, but you can call to order. The online product should be up early next week.
- The Turn One Team
Whats updated?
Old Aug 15, 2020 | 12:30 PM
Is this 15” cooler overkill?
Old Aug 15, 2020 | 02:17 PM
sjsingle1's Avatar
where are you going to put that monster ??
Old Aug 16, 2020 | 05:00 PM
Old Aug 16, 2020 | 07:48 PM
wssix99's Avatar
Save the manuals!
... and how much plutonium does it hold?
Old Aug 17, 2020 | 01:45 AM
sjsingle1's Avatar
I used a simple fin type cooler.....works great.....the bigger the cooler.....greater chance it will snag on something.....ask me how I know
Old Aug 17, 2020 | 04:46 PM
wssix99's Avatar
Save the manuals!
I like this cooler, with the thick fins. ^ I'm interested to see how it holds up after the air deflector has kicked back on a few curbs and parking lot wheel stops. My thin fins get bent and knocked around a bit - no big deal, they can be straightened. Hopefully these will stay stout.
Old Aug 17, 2020 | 04:49 PM
sjsingle1's Avatar
the bigger the cooler ...the better the cooling ....but bigger is not always better
Old Aug 17, 2020 | 07:19 PM
Is that replacing the one connected to the radiator hose or are you increasing the volume of the system?
replaced the upper hose with one that does not have steering cooler.
Before my pulley came off I noticed the steering got hard after running high rpms so this should keep the rebuilt pump much cooler.
Old Aug 18, 2020 | 09:15 AM
steering_experts1's Avatar
Originally Posted by wssix99
When do we get to see!!!
@wssix99 @sjsingle1 Products are online now for the new HP1 and HP2 Fbody pumps (FYI...HP1 and HP2 are new pump classifications for almost all our pumps, having standard tuning modifications for each. Similar to the common Stage 1 and Stage 2 performance upgrade designations.)
@blkbowtie98 Great question! We upgraded the Type II pump style from the factory bushing-style CB pump to a bearing-style TC pump. The bearing-style pump will allow for moving the pump out of the factory mounting position, making it compatible with additional aftermarket LS accessory drive kits that utilize the Fbody pump in non-factory mounting positions (the bushing design was extremely sensitive to belt load and tension angles to function properly). We can now also perform the driveshaft upgrade on the pump for supercharger applications that run off the accessory drive belt. Nothing changes in terms of our standard performance upgrades regarding pressure and flow rate changes/customizations. The one semi-drawback is that the pump style use a different driveshaft diameter, so the new pump is not compatible with factory pulleys, and therefore is also being sold as a bundle that includes one of our billet aluminum pulleys (factory diameter).
Old Aug 18, 2020 | 01:41 PM
  #32
00PewterSS's Avatar
Originally Posted by blkbowtie98
I have the same cooler mounted in the same location. Turn-one said I would likely not need a cooler. But one very busy AutoX in hot weather overheated it so much I didn't have any assist at the end of the run (without the cooler). With the cooler I haven't had any trouble.
Old Aug 18, 2020 | 03:12 PM
  #33
sjsingle1's Avatar
a cooler and using syn fluid helps keep the pump cool an the seals lasting longer ....IMO....the seals in my rebuild were cooked with a capital K ! no sealing is a nice leak.....
turn one....that new pump really looks spiffy !
Old Sep 10, 2020 | 08:46 PM
  #34
So I sent my old pump to T1. They rebuilt it and called to say it was basically beyond repair. I went ahead and ordered the new style pump and got it on. It’s a nice quality unit.
The car was down for a month while waiting for rebuild. I had the battery unhooked and now The
ASR off is lit and button doesn’t nothing.
