Uneven suspension
Old Aug 25, 2020 | 12:11 AM
2001ws6ft's Avatar
Default Uneven suspension
I recently replaced my shocks. I haven't been able to get it to the alignment shop yet, planning to this wednesday. When I was jacking up the car, I noticed the front passenger side wheel takes longer to lift off the ground. It's a very big difference, probably an inch and a half. I'm guessing it's just the car being out of whack with the alignment. What else can be causing this?
Old Aug 25, 2020 | 09:10 AM
VIP1's Avatar
Copy & Paste Moderator
So you are just jacking up the car and a wheel comes off the ground at a different rate than the others? That as much an issue of where you jack it and the strength of the chassis as it is suspension or alignment. I bet if you try again with the jack in a different spot, you'll see different results. Every car ever is like this. Maybe I'm not understanding what you are seeing or you are seeing normal physics.
