Abs bleeding tool & securing brake lines
Old Jan 25, 2021 | 11:46 PM
LETZRIDE's Avatar
Default Abs bleeding tool & securing brake lines
I know there are snap on and GM tech II tools that are used to cycle the abs to bleed the brakes- but with advancements in technology, are there any other tools out there for under $150 that cycle the abs so that I can bleed my brakes in my 4th gen?
I replaced my brake lines entirely from the abs block to the rear and the master went dry.
Also, I am deleting the metal bracket that the two rubber brake lines went to that splits the axle brake lines. With my Ford 8.8 there was no where to bolt it too and it seemed to get in the way. Anyone have photos of how they secured their brake lines to the axle so that they didn’t move around?
Old Jan 26, 2021 | 07:27 AM
sjsingle1's Avatar
only thing I have found is the autel maxi check pro auto bleed tool....199$ on amazon...have not used it yet so cant say how well it works
