Sub frame connectors
Old Sep 20, 2021 | 06:59 PM
willcason's Avatar
Default Sub frame connectors
Looking at speed engineering sub frame conn
ectors weld in, anyone used them?about $100 lower than the BMR.
Old Sep 24, 2021 | 09:48 AM
MidwestChassis2's Avatar
Keep in mind anything that attaches to the lower control arm bracket is a glorified jacking rale. If it is not welded from subframe to subframe it is not serving its purpose of being a "subframe connectors". We offer true subframe connectors for the same cost if not less than the ones that do not attach to the rear subframe.
https://midwestchassis.com/products/...-powder-coated
Old Sep 24, 2021 | 04:21 PM
willcason's Avatar
Default Midwest chassis
How much massaging do I have to the underside of the car. My only concern?
Old Sep 24, 2021 | 04:37 PM
Not much at all, you won't tell under the vehicle or inside once done.
