K-member ?
Old Oct 12, 2021 | 10:05 AM
69PrimedC10's Avatar
Default K-member ?
Ok so I have a 02 3.8 liter camaro and a 01 z28 camaro. I was going to swap the k member out but to me they look identical. The v8 kmember also had the clamshell mount on the member itself just like the 3.8. I bought this car without the motor so I'm wondering if someone had already swapped it. Is there a way to tell the difference by just looking at them. Thanks for the help!
Old Oct 12, 2021 | 11:32 AM
blackbyrd's Avatar
they are different despite looking similar, the arms that bolt onto the k memeber that hold the motor mounts are different between 3.8 and the 5.7ls1. I believe they bolt to different locations on the k member also but never confirmed that. Ive done the swap and I went to a umi k member since I was going iron block up front.
Old Oct 13, 2021 | 07:39 AM
01CamaroSSTx's Avatar
↑↑↑This is correct↑↑↑
They are the same with the exception of the motor mount locations.
Old Oct 13, 2021 | 08:12 AM
Thanks! I actually picked up a ls crossmember yesterday afternoon and there is definitely a difference. Some one had put a 3.8 crossmember under the z28.
