Help on launch
Old Dec 18, 2021 | 08:33 AM
V8EATR's Avatar
Default Help on launch
I know it's not a gm but it's gm powered and I figure some of you guys probably know whats up. This was a 9.0 with a 1.31 sixty. Team z stock location springs, bmr arms, tube welded 8.8 with good 31 splines and a carbon t-lok. It also has a steeda sway bar. This was close to 250lbs of sand in the trunk. I'm thinking of adding an anti roll bar. Do you think with that, I could match or beat my current 60 with the ballast weight out? Thanks.
Old Dec 18, 2021 | 08:54 PM
Z28SteveA4's Avatar
From the looks of it that left tire is coming up way higher then the right front. Usually anti roll bar fixes that!
Old Dec 20, 2021 | 02:30 PM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
Originally Posted by V8EATR
https://youtu.be/GRybCI5bCfw
It is hard to tell what the suspension is doing with the body roll. An antiroll bar will fix that. What shocks and struts are you running?
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
