Wheel rub - Alignment Problem - Control arm upgrade
Old Apr 12, 2022 | 09:13 PM
adman jones's Avatar
Default Wheel rub - Alignment Problem - Control arm upgrade
I recently replaced the stock upper/lower control arms with UMI A-Arms (lower is adjustable), inner/outer tie rods on my 02 SS SLP. When reassembling, the top inside of the rim rubs the top of the steering knuckle just under the upper ball joint. UMI says those adjustable lower A-Arms are set to factory spec. I’m a YouTube DIY kinda guy, I feel like I’m in over my head. My first thought was wheel spacers. The car is still on stands, I’m unsure of what to do next. Any experience with this?
Old Apr 13, 2022 | 01:23 PM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
Sounds like the alignment may be way out. Have you tried adjusting the lower arms in the kmember to help?
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old Apr 13, 2022 | 02:57 PM
No. I’ll try adjusting that way. Will let you know. Thanks
