BMR torque arm bracket
Old Apr 24, 2022 | 02:07 PM
xenergyx's Avatar
Default BMR torque arm bracket
02 TA
I finnally got some time to modify the bracket to use the inner holes of my BMR bracket how it hits the Driveshaft and the nut that holds the top part of the arm to the bracket. Was this even the right bracket? what can be done to fix this?
Ps this is with the stock 10 bolt rearend.
Before
After
e bracket.
Old Apr 27, 2022 | 11:26 AM
biketopia's Avatar
The inner holes on the torque arm brackets are for aftermarket rear ends, why did you cut yours when using it on a 10 bolt?
Old May 5, 2022 | 12:20 AM
91 Z28's Avatar
Originally Posted by xenergyx
02 TA
Before
After
e bracket.
You ruined your bracket for no reason. The inside holes are for aftermarket rear ends not stock 10 bolts. Why did you do that??
