Torque specs
Old Aug 16, 2022 | 10:04 AM
lowchevytrucks8503's Avatar
Default Torque specs
Put my car on the trailer, strapped it down and noticed this bolt was loose. The nut is missing. I am gonna have to pull the bolt out and go find a nut and washer for it. Does anyone have a torque spec for it??
Old Aug 16, 2022 | 11:35 AM
SAPPER's Avatar
Ugga-dugga 3 to 4 times. Preferrably using a Lock nut of some sort.
Old Aug 16, 2022 | 01:39 PM
ghardester's Avatar
That looks like the bolt to your tubular lower control arms. I happen to have the instructions (UMI) right in front of me because I am getting ready to swap my tubulars out with another set while I put new bushings in the old set.
When you tighten that bolt up the car needs to be jacked up by the rear axle, place jack stands under the axles, then let the weight rest on the jack stands to prevent bushing pre-load. Then tighten them to 72 ft lbs.
Old Aug 16, 2022 | 02:13 PM
WBO_COTTO's Avatar
Seems right I just did ADJ Pahnard bar and SB was about as tight as lug nuts almost
Old Aug 16, 2022 | 09:16 PM
perfect! After beating the hell out of the bolt to get it to slide in since I couldn’t get the mount on the 9 inch to line up, I torqued it to 100 ft/lbs
i’ll do exactly what you said in the morning and go to 72 ft lbs!
Appreciate the replies guys!
