Brake fitting size and flare type
Old Oct 23, 2022 | 11:12 AM
Bosshog's Avatar
Default Brake fitting size and flare type
Was curious if anyone knows the correct size fitting and flare used on the abs block on the 2002 z28s for the Front Right brake line ? Thanks
edit : I could probably find out myself but the threads are mangled and the flare is messed up. So figured someone would know
Old Oct 23, 2022 | 11:23 AM
01CamaroSSTx's Avatar
3/16 inverted flares and the local parts store will have the line and fittings. Don't waste your time with those cheapo rentals from the local parts store, I've used them but it took several attempts before done correctly and not leak.
Old Oct 23, 2022 | 11:47 AM
Bosshog's Avatar
alright so id assume 3/8-24 fitting then ?
Old Oct 23, 2022 | 12:49 PM
I'm inclined to say yes but i'm not sure if it's the same thread pitch for the ABS block. Maybe someone else will chime in here.
Old Oct 23, 2022 | 02:14 PM
Bosshog's Avatar
looks like it actually might be M10x1.00
Old Oct 23, 2022 | 03:09 PM
QwkTrip's Avatar
The rest of the brake system is metric bubble (various thread sizes). I'd be surprised if the ABS block breaks with that philosophy. All you need is a thread checker tool to figure out thread size. Regarding the flare, post a picture and I can identify what kind of flare it is.
http://www.fedhillusa.com/?page=flare
