DIY abs delete question
Old Apr 20, 2023 | 05:02 PM
Codys89RS's Avatar
Default DIY abs delete question
Looking to decide if I go sjm abs delete or do it myself with a homemade kit.
wanted to know if anyone has used this t or something like it to feed stock lines into.
https://www.jegs.com/i/JEGS+Performance+Products/555/63076/10002/-1?gclid=EAIaIQobChMIv-qv6bm5_gIVcySzAB3TTw3dEAQYAiABEgJTDvD_BwE
have linelock and would buy the proportioning valve.
thanks in advance!
Old Apr 22, 2023 | 06:03 PM
Undertow74's Avatar
I would say go with sjm. I'm just letting you know, though, flaring the stock lines with the engine in is going to be a bitch. They are hard as **** to double flare and i did it with engine out. Make sure you buy an on car flaring tool like the one eastwood sells will make your life way easier!
