Frt Coil Spring Install
Old Jun 18, 2023 | 09:22 AM
Roadster31's Avatar
Default Frt Coil Spring Install
I am installing new front springs. I am using a spring compressor. When I lift the lower control arm I am 1/2 inch short from being able to get the ball joint pin down where I can attach the nut. What starts to happen is the car starts to lift Vs just the control arm. This is not an engine out issue. I have seen some secure a chain around the jack and frame to stop frame from lifting but have not tried that yet. Any suggestions?
Old Jun 18, 2023 | 11:36 AM
98CayenneT/A's Avatar
Are you saying you disconnected the lower ball joint as opposed to the top ball joint in order to remove the front coil over?
Old Jun 18, 2023 | 02:21 PM
Roadster31's Avatar
It isn’t a coil over, it’s a separate shock and spring. Yes, I disconnected the bottom ball joint to drop the LCA.
Old Jun 26, 2023 | 08:35 PM
michaelvp's Avatar
if this is f body design upper and lower control arm, are you using a spring compressor that goes up through the center of the spring where the shock would normally be?
