Upper Control Arm Angle?
Old Jul 24, 2023 | 07:32 AM
KaMiKaZi's Avatar
Default Upper Control Arm Angle?
Removed both the lower and upper control arms to replace the rubber bushings and ball joints but I didn't mark the angle between the upper mount and the upper control arm before taking it apart.
Searched around and read on other threads to put everything back together a little loose and then tighten up the UCAs when it's at "ride height" or when the suspension is preloaded. Do I have to put the wheels back on and put the car on the ground? Or can I reconnect the upper and lower control arms to the steering knuckle and jack up the lower control arm to put tension on everything? How do I know when I put enough load on everything so that I can tighten?
Front end of the card is on jack stands so I can use my floor jack under the lower control arm.
Old Jul 24, 2023 | 10:50 AM
Woodylyf767's Avatar
Not sure what car you're using
But the organization I'm a part of usually leaves it loose, get's the car on a drive on lift, then tighten
So it's sitting on its wheels before they tighten
Old Jul 24, 2023 | 12:18 PM
KaMiKaZi's Avatar
'02 Trans Am.
At this point, if the wheels need to be on and on the ground, I may just put on everything loose, jack it down to the ground, mark the angle, and then jack it back up, remove, and torque to spec. Seems like a PITA, but I want to get it right and not tension the new bushings in the wrong position...
Old Jul 25, 2023 | 03:09 PM
So marking it and then tightening it up with the wheel off but in the same position? Sounds solid
Old Sep 3, 2023 | 02:12 PM
Rt Jam's Avatar
No, follow the instructions in the 2nd reply.
