4th Gen Alignment DIY?
Old Aug 20, 2023 | 06:49 PM
F14D's Avatar
Default 4th Gen Alignment DIY?
My 93 needs one. I understand I need this tool to properly do a front end alignment. Ive noticed my front tires are wearing on the outer edge. The steering wheel is a bit sloppy, almost 1/2 to 1 inch of play as well so any minute turn leads me to correcting. Otherwise on flat surfaces it drives straight. Konis on lower perch, new tie rods, rack and Pinion, 275/40r17s, and a 35mm solid is what's all been done.
Any vids or tutorials I could watch? I have access to an alignment rack at work, but I would like to try and get some info beforehand. I've read through threads and based on outer edge wear, one person recommended Toe it out .05 more than spec. Sound good?
Old Aug 20, 2023 | 07:28 PM
wannafbody's Avatar
Toe out makes for twitchy driving. I go with 0 toe but you could toe in slightly.
Old Aug 22, 2023 | 07:52 PM
F14D's Avatar
Yes, twitchy. When I got the new tie rods, I counted the rotations on the removal and reversed on the install. I'll check for toe in. Watched a couple videos, I think I can do that this weekend. Jusy the outer 1/2" is wearing fast.
Old Aug 22, 2023 | 10:12 PM
wannafbody's Avatar
You need to check the new tie rod end compared to the old one. I tried marking the threads but the length was different between them and threw me off. I was off by 1/2 inch.
Old Aug 23, 2023 | 12:18 AM
F14D's Avatar
Old ones are long gone. I was careful as I thought I could be and sat them side by side and counted rotations. They measured similar enough to continue my caveman method. But here we are..
