Separating shock from shock mount
To be clear, I'm talking about these:
(I also replaced the inner shock mount isolators, but had no issues there.)
On the driver side shock, the mount came right off the shock. But on the passenger side, it won't. The nut is off, but the mount seems to be stuck to the shaft. It looks pretty rusty, so I'm assuming that's how and why it's stuck.
I've seen a handful of threads about this, but it was always in the context of replacing shocks, so the advice was always "just throw that whole thing in the trash and buy a new shock mount to go with your new shocks." Well, I can't do that; I'm not replacing my shocks. I need to separate these two pieces, and I cannot damage the shock itself in the process.
Right now I have it held upright, with a pool of PB Blaster sitting in the top of the shock mount, hopefully making some headway. I've done a good bit of hammering against the top of the shock, hoping to dislodge it from the mount -- but despite its worn state, the mount's rubber is doing a pretty great job of absorbing those hits. (My primary motivation for replacing the mount is to replace the rusty shock tower bolts.)
This evening after work, I plan to get out my air hammer and see if that can break anything loose. I'm a little wary of this, because I definitely don't want to mushroom the top stem of the shock too much. Does anyone have a good way to protect it from this? I guess I could thread a nut on and then put a deep socket (too small for the nut) over the top, but I'm all ears for better ideas if you have them.
Does anyone have any other ideas I could use to get these two pieces apart?
I lubed the shaft with some anti-seize, so hopefully this goes a little more smoothly the next time these need to come apart!
