Subframe Connectors
Old Sep 6, 2024 | 07:58 AM
SteveC's Avatar
From: Poway, Ca. where GOD and the sun always shines
Thumbs up
Originally Posted by Carguy8888
What are you referring to as a U-Brace? Strut tower brace, panhard bar or something else?
I guess the proper term would be "Tunnel brace", it is a heavy duty U shaped object that bolts to both sides of the SLP 3 point sub frame connectors tying them together for extra strength and goes under the drive shaft. I tried to find a picture of it @ the BMR site, however they do not carry it anymore.
This picture is pretty close to what I have from a different manufacturer:
This is not the BMR brace, however it will give you a good idea of what I have installed
Old Jul 15, 2025 | 01:17 PM
JR2000Cam_SS_SLP's Avatar
Default UMI Bolt-On SFCs
Originally Posted by KobeGigi
Interesting! So, in reality the bolt ones work really well.
i’ve had the bolt on connectors, on my convertible ‘00 Camaro, for 8 years, and they’ve worked fantastically. Like the gentleman before, I also use Loctite on the two front bolts, and I’ve checked them once a year; so far they’ve not come loose at all. If you do use the bolt on subframe connectors, and you find that they are coming loose, you can always add weld on some 1/4” plates, much like the UMI SFCs that have both bolt-on ( front mount ), along with two plates on the sides.
