Brake Bleeder Valves
Greetings,
In the process of trying to change out brake fluid, I found my rear bleeder valves to be so stuck that I have started to strip them. Before I go too far and ruin them, I wanted to order replacements. However, I can’t seem to find specifics on the rear ones. Are they the same as the front? If not, any details on part numbers? I’ve been able to find front valves, but they don’t specify if they fit the rear. Any help is appreciated!
Thanks for the info. I guess I could’ve helped you out better with my actual car info 😂. Front and rear, says it right there on the label. Not sure why I didn’t see it there before, but thank you again for the assist!!
Greetings,
Once you get the new bleed screws, if you haven't already been able to loosen the old ones, you could try using a pair of "mini" Vise Grips to grip and loosen them, because at that point, you'll have new ones to install.
