torque arm needed???
Old Aug 21, 2004 | 02:14 PM
Raise's Avatar
Default torque arm needed???
im tryin to build a hell of a street car...and maybe get into autocrossin one day. right now i have an 02 bolt on car with a tr224 cam in. i was gonna go with some stage 2 heads to get the power i wanted out of the way...but i have stock suspension...so i figured id wait on the heads and go ahead and build me a hell of a street car that handles like a dream. heres wut i have covered: (ordering soon) tower brace, swaybars, subframes, lcas, ph rod, socks/springs. i wanted to ask about the torque arm....is this something i will need even though im not gonna be drag racin/launchin much??
Old Aug 21, 2004 | 04:37 PM
Fulton 1's Avatar
Well, a "hell of a street car" deserves a hell of a torque arm, don't you think?
Old Aug 21, 2004 | 05:05 PM
Raise's Avatar
well, wut exactly does the torque arm do?
Old Aug 21, 2004 | 07:31 PM
98_1LE's Avatar
The main thing the torque arm does is keep the pinion from going up or down relative to the driveshaft, or controls pinion angle. This is critical.
I have the LG Motorsports torque arm. It has a spherical bearing up front, which prevents binding through it's range of motion. Poly will bind up.
I would pass on the shock tower brace, they do almost nothing for fourthgens. I would suggest a 35 or 36mm front sway bar (ST solid, Strano hollow, or Hotchkis hollow), good shocks (Koni's or Bilstein's). I have used several springs (1LE, SLP Eibach, Eibach Prokit, and LG G2), and not suprisingly, I like the G2 springs the best. For lower control arms I would use either 1LE or aluminum LCA's with dual rod ends. Again, LG makes a nice part. Ditto for the panhard bar. Subframe connectors are good, be sure to weld them in. Once you are this far, good tires are a must. To be honest, if you do nothing else, put good sticky tires on the car. They will do more for handling than anything that you can bolt to the car.
But the single tihng that will make more time on an autox course is seat time, ie experience. The first (and second) time a stock Miata or Integra kicks your butt by as much as you could beat it on the dragstrip (or worse), you will learn the power of the driver.
