Which Shocks for a lowered TA?
Old Sep 19, 2004 | 01:48 PM
Hooterman's Avatar
Default Which Shocks for a lowered TA?
I just replaced my entire suspension, except for the shocks. Why the entire suspension, well I bought 17" rims with the fatest tires and the handling was not what it should be. The handling now is excellent. I lowered the car using Eibach's Pro Kit springs. The shocks don't seem to be up to the task on bumps, as the car hits the rubber pads that prevent the tires from bottoming out up against the wheel wall area. The car handles much much better then the factory setup, except for the bumps that cause the car to bottom out. Any recommendations for the best shocks, price is not the issue. Thanks!
Troy Turnbaugh
Old Sep 19, 2004 | 03:15 PM
98_1LE's Avatar
Car looks great. I also have a red/taupe flat hood T/A.
I have and would suggest Koni single adjustable shocks. They work great with the Pro-kit. I got them from Sam Strano.
Old Sep 19, 2004 | 09:36 PM
2w0s060's Avatar
I hear Sam is good with this, I run the Bilstein HD's with the Pro kit. Rides great
Old Sep 20, 2004 | 09:47 PM
Hooterman's Avatar
Default Thanks!
I have to changes these stock shocks sooner then later! Troy
Old Sep 27, 2004 | 12:34 PM
transambandit's Avatar
I went with the KYB 8 way adj, i think they are great, the lowest setting is much better than stock for a soft ride and the higher you go, the stiffer. But i think they ride incredible
