BMR Relocation Brackets
Old Oct 2, 2004 | 02:36 PM
uLs1a's Avatar
Default BMR Relocation Brackets
I installed BMR bolt on relocation brackets last night and I unscrewed a brake hose with the clip. Once I screwed them back together it kept on leaking brake fluid and it still does. IS there anyway for me to stop this leak?
Old Oct 2, 2004 | 10:53 PM
Gloveperson's Avatar
Do you screw it back completly? You could try bleading it completly and re-fill it to see if it is a pressure issue, too.
-Todd
Old Oct 3, 2004 | 12:29 PM
2w0s060's Avatar
Yea make sure its screwed in the whole way, those fittings are tappered and will appear tight when they are not fully in.
Only other thing is you stripped it, which is kind of hard to do
