Please help with SLP STB install.
Old Nov 27, 2004 | 05:24 AM
Adinsx's Avatar
Default Please help with SLP STB install.
I know what you are all thinking, STBs are the easiest bolt-ons out there. But for some reason mine just will not fit. I've emailed SLP and they said to have a second person press down in the middle and it will spread just enough to get it on. I've tried myself and it won't budge. I have used BMR's version in another car and it was simple. Has anyone else had this problem? Thanks.
Old Nov 27, 2004 | 05:49 PM
VIP1's Avatar
Copy & Paste Moderator
I recently installed a Hotchkis STB. It wouldnt fit until i elongated the holes in the brakets and shimmed them bit (additional shims, not the shims that they come with). It still took a little prying to get it on. I know the front of my car is a bit tweaked (previous accident). Your's may be too.
You said that you have installed the BMR STB on other cars. See if you can borrow one. Try to put it on your car and try to put the SLP STB on the other car. This will identify if the problem is with your car or with the SLP STB.
Old Nov 27, 2004 | 05:58 PM
davered00ss's Avatar
Moderator
Try with a friend, one person on each side and start the holes at the same time. I have the BMR and it slid right on.
Old Nov 27, 2004 | 08:35 PM
skewba98z28's Avatar
Yeah my hotchkis took some beating and banging to get it on. I think that's just the nature of the STB. also I would make sure your car is setting on a level surface. Other than that just get a BFH and persuide it a little.
Old Nov 27, 2004 | 10:41 PM
2w0s060's Avatar
I've installed 2 UMI STB's so far...no problems here
Old Nov 28, 2004 | 12:47 AM
Cal's Avatar
Cal
My SLP STB went on fine, it was just a little hard to get the inside nuts started. Then I found out our cars don't need a STB, so I took it back off. You might try taking the edges of the holes off with a rat-tailed file.
