LCA relocation
Old Nov 29, 2004 | 11:51 AM
squall01's Avatar
Default LCA relocation
i've heard that this is necessary for lowered cars. I'm just wondering what all problems these fix?
Old Nov 29, 2004 | 12:00 PM
Bad Blu Formula's Avatar
The only problem these are suppose to fix is wheel hop. Wheel hop can equal death to your rear end and tranny mount.
Old Nov 29, 2004 | 05:35 PM
95_Firehawk_Dude's Avatar
I agree. Just did my QA1s and it lowered the rear a little. Need to get them relocated now.
Anyways... i went to the track after the QA1s and got some wheel hop that i never got before beucase of the LCA install with stock suspension. Can just a few passes ruin the tranny mount? How will you know? I'm getting a weird noise but not all of the time and this was my first guess on to what it was and then you mentioned it. Any suggestions. Its like in and out of gear, sometimes while in gear. And its not a constent sound. Sounds like something is rubbing? I thought at first it was exhaust clamps on the driveshaft but that should happen anytime i'm moving. Plus i got those welded up but the sound is still there.
Thanks
Old Nov 30, 2004 | 12:30 AM
JohnR's Avatar
Relocating the rear lower control arms on a lowered car will correct the suspension geometry. The LCA's should be level or slightly low in the rear. When the rear of the LCA's are lower, they will create a small downward force on the rear end upon acceleration, and give you more traction.
