C5 rotor upgrade
no way will they fit with out some specialty parts. i actually have a set of bob bishop brake brakets for my car. these brakets allow me to use C5 rotors and calipers on the front. cutting the stock spindel is required as are 17 in wheels.
get some hawk HPS brake pads and make sure your fluid and lines are good and new and youll be very surprised at how well the car will stop
bigger rotors will not make you stop faster, they will only allow you to stop harder repeatedly. by that i mean if your road racing the car you will not suffer brake fade as quickly as an identicle setup(ie same pads, caliper style) if your using larger rotors. larger rotors allow the heat to go somewhere other than the rotor surface and pads.
if you are suffering brake fade and your not road racing the car, you need to change your fluid and get better pads, changing to a larger rotor is a waste of money.
