ABS Delete/Line Lock
Old Dec 16, 2004 | 11:09 PM
code4's Avatar
Default ABS Delete/Line Lock
Well I have been working on my new line lock & brake system mod for several days now. I looked for adapters until my head was about to explode because I wanted it to look factory. Well I could adapt regular 3/8-24 IF lines to the master cylinder, that took some research. If anyone is interested I can hook you up with those two adapters. So now your lines will hook to your proportioning valve & linelock with the supplied 3/8-24 IF to 1/8 npt adapters. With me still?
Now there is no such thing is this world that will adapt your factory brake lines (M10 X 1.0) to the other end of your LL & Proportioning valve. So I broke down and cut the factory metric fittings and installed the 3/8-24 fittings. Then I used a flaring tool to do the Inverted Flare. Came out great!
If anyone is interested on exactly how my system is set up let me know. This is for non street use of course as I no longer have ABS My dash is lit up like a christmas tree now, tis the season.
