Setting an adjustable Panhard bar?
Old Dec 20, 2004 | 11:50 PM
SLPformula's Avatar
Default Setting an adjustable Panhard bar?
What is the best setting on a fully adjustable PHB with eibach prokit, bilsteins, and 17x11 zr1s w/315s?
Old Dec 21, 2004 | 06:10 AM
JackZ28's Avatar
You'd have to play with it until your car is right. Each car is different, even if only by a millimeter or two.
Old Dec 21, 2004 | 10:07 AM
Bad Blu Formula's Avatar
It takes a while measuring on each side until its perfect.
Old Dec 21, 2004 | 10:17 AM
DARK AGE 53's Avatar
http://www.bmrfabrication.com/instructions/phr002.htm
Old Dec 21, 2004 | 10:34 AM
mitchntx's Avatar
The goal is to get the rear wheels to track on top of the front wheels.
On my driveway, I sprayed a small section of water on the concrete. It doesn't take much, just enough to get the tread of the tire wet and leave a pattern on the dry part of the driveway.
I rolled the car through the wet spot and looked at the tread pattern left by the water on the tires.
I measured the offset (front vs rear), divided it in 1/2 and adjusted the PHB to the appropriate length.
It might take you a couple of tries, but it certainly gets it spot on ....
Old Dec 21, 2004 | 04:36 PM
SLPformula's Avatar
Thanks alot. All very helpfull. By the way i have a bad *** PHB. Its made by BAD Z Components. Ill get some pics up.
