Roll cage question
Old Jan 7, 2005 | 08:52 PM
nikon1999's Avatar
Default Roll cage question
Hi all, sorry not sure what forum area to post this under, but i figured i'd try here. Just finished putting a 6pt wolf roll cage in my car w/ swing out arms and had a few quick questions. Both swing out arms when you open them drop down after you take them off the main hoop? i assume thats normal just curious. And oppositely when i try to put the pin in to shut them its very difficult, passenger side worse then driver? The front bolt pads only would really work one way drilling through under the car, only one place where i could drill all holes and be able to put a nut on the opposite side. The other 4 pads seemed to be perfect, the spacing is symmetrical all around between cage and car. I couldnt' have possible mis aligned something? Last question, any torque specs for the bolts or just crank them down? Sorry for the long post, just want to make sure everything is right before i put it all back together. Thanks!
