1le
Old Jan 19, 2005 | 01:14 AM
chris77's Avatar
Default 1le
dose anyone know how much bigger the 1le sway bars are then the stock ones, are they worth getting.
Old Jan 19, 2005 | 01:33 AM
Judd's Avatar
I believe the front sway is 32mm, 2mm larger. The rear is the same at 19mm except for an older model {I think it was a 3rd Gen}which was 21mm. I really don't think it's worth the effort unless you could find em used for cheap. Buy a 35mm solid {cheap} or a 35mm hollow {pricer}. Give Sam Strano a call.
