c5 Brake conversion on a LT1?
Old Jan 24, 2005 | 05:30 PM
WhiteSSP's Avatar
Default c5 Brake conversion on a LT1?
What all is needed for a conversion to C5 Corvette brakes on a LT1 Firebird? As far as i know, this is the parts list:
Brackets
Rotors
Pads
Calipers
Brake lines
Where can you get the brackets from? Am I missing anything else?
Thanks,
Shawn
Old Jan 25, 2005 | 02:00 PM
jargan04's Avatar
Brackets
Rotors
Pads
Calipers
Brake lines
Thanks,
Shawn
If you want to keep the spindles. Then the only bracket that will work is the Bob Bishop one. You might want to try this forum. http://frrax.com If you want to you the LS1 spindle then you can get the brackets from LG, they are 249.95.
