LCA Question
Old Feb 1, 2005 | 09:17 AM
SmokeShow99SS's Avatar
Default LCA Question
I have the Hotchkis LCA and Pan Hard Bar. The question is on the PHB the grease fitting are normal size for a grease gun but the one's on the LCA are smaller, what do i need to grease them?
Also the other night i was driving and hit 2nd and heard a loud thud/clunking? What could this be from I looked under it and didnt see anything wrong. . . but haven't put it on a lift to get a better look. Thanks for the help!!!!!!
Old Feb 2, 2005 | 12:55 PM
anyone ????
Old Feb 2, 2005 | 01:10 PM
Caribe's Avatar
As for the clunk try tightening the bolts for the upper panhard bar. This happen to me about 6 months ago.
Old Feb 3, 2005 | 09:10 AM
Sunset01SS's Avatar
I've had my LCAs on for almost a year and I haven't tried to grease them yet. Now that you mention it every now & then I get a thud when getting sideways. I think it may be a little wheel hop & with the bushings they have on the Hotchkis LCAs it's louder than w/the stock ones. For the most part I don't get any wheel hop though and I think they work great.
Old Feb 3, 2005 | 04:47 PM
Zepher's Avatar
The clunk could be the TQ arm mount. It's hard to tell if the bushing is bad without pulling the TQ arm down. Mine looked good but when I pulled the TQ arm out I could see where the arm was going up and down through the bushing and hitting the metal bracket. I installed an ES bushing in it's place.
Old Feb 7, 2005 | 09:03 PM
BADZ's Avatar
Moderator
Make sure all is very tight as sometimes the nuts may back off.. I use a bit of lock tight but not too much...
