brake bleed
Old Feb 5, 2005 | 07:56 PM
RedWS601's Avatar
Default brake bleed
Does anyone know how to bleed brakes? I got new rotors and pads and before I try to break them in I'm going to change the brake fluid. Help
Old Feb 5, 2005 | 10:23 PM
Fulton 1's Avatar
http://www.stoptech.com/whitepapers/...rakesright.htm
Here's a great tool if you don't have access to an air compressor: http://www.griotsgarage.com/catalog....2050&SKU=85700
Old Feb 6, 2005 | 09:38 AM
Bad30th's Avatar
Here's a writeup I did a couple of months ago :
https://ls1tech.com/forums/suspension-brakes/251569-how-w-pics-bleeding-earl-s-solobleed-bleeders.html
If you don't use the Earl's SoloBleed bleeders you'll need a friend to push the pedal while you open/close the stock bleed valves.
Good luck,
Bad30th
Old Feb 6, 2005 | 12:40 PM
Poik's Avatar
Originally Posted by Fulton 1
And how is the air compressor used if one does have acess to one?
Old Feb 6, 2005 | 02:54 PM
Fulton 1's Avatar
If you have access to an AC then you can use vacuum bleeding tools (e.g. http://www.trackhaus.com/product-exec/product_id/343 ) or pressure bleeding tools (e.g. http://www.sjdiscounttools.com/gensym-4.html ) that require the use of shop air.
