Bent torque arm mount!
Old Feb 12, 2005 | 01:34 PM
shaulinmathvader's Avatar
Default Bent torque arm mount!
Bent the torque arm mount. Does any one sell a aftermarket torque arm mount. I have found the torque arbushing for example on ls1speed.com but it looks like only a bushing that slides into the bracket I need the bracket is there an aftermarket one to go on a stock torque arm Please help
Old Feb 12, 2005 | 02:52 PM
MeentSS02's Avatar
Kleeborp the Moderator™
You'd most likely just have to check with your GM parts dealer...if they won't sell it separate, you'll have to get a new torque arm. You can get by with a pretty cheap one, but if you bent the stocker, it might be time for an upgrade anyways. I don't think there are any aftermarket torque arm mounts for the stocker...
