K Member ???
Old Feb 12, 2005 | 04:45 PM
mikes02ls1's Avatar
Default K Member ???
Can I put a PA Racing K member in with out taking the engine out? I wonder if they make a tool to hold the engine in place while I remove the K member. Let me know what anyone thinks.
Old Feb 12, 2005 | 05:14 PM
RDTA's Avatar
just use a engine hoist to hold it up, I used 1 hole in the head on the pass side and ps pump hole on the other side. But the fun part is if the motor mount bolts come in from the front you will have to take the alternator loose, the starter, ac compressor and its mounting bracket off to get the bolts out good luck Brian
Old Feb 12, 2005 | 07:31 PM
mikes02ls1's Avatar
Thanks for the info, anybody else?
Old Feb 12, 2005 | 07:57 PM
98TAauto's Avatar
my motor is outta the car lready so my PA is going on fairly easy hopefully LOL....
just get a cherry picker to hold the motor up while you drop the k member
