suspension upgrades
Old Mar 1, 2005 | 01:03 AM
nvrstsfd23's Avatar
Default suspension upgrades
I have a 02 m6 ramair TA. What upgrades to the suspension should I do. I got eibach springs and a strut tower brace. I want to make the car handle great. Any suggestions would be great.
Old Mar 1, 2005 | 01:29 AM
Judd's Avatar
Good shocks {Bilsteins as a minimum, Koni SAs prefered} is the biggist improvement. Might want to change those springs for some a bit stiffer, maybe coil-overs with something in the 500-650 range. If you really like those Pro Kits,, they would work fine on a street car. That would be a good start. Maybe 35-36mm hollow front bar and Sam Strano's 22mm hollow rear bar. Almost forgot,,, a good alignment. Something like -1.0 to -1.5 degrees of camber in the front would be good for a street car.
Old Mar 1, 2005 | 09:03 AM
nvrstsfd23's Avatar
what about airbag systems are they worth anything or not.
Old Mar 1, 2005 | 10:46 PM
Judd's Avatar
I don't know anything about air bag systems, so I can only comment on what I have or what most people have at the the track or AutoX course. I've never seen a car with air bags at either. If they were good for that stuff,, most likely you would see alot more of them. JMO
