Installing a line lock, need help please.
Hummer
Pump, pump, pump...open. Until you see no air. I attached a small rubber line to the nub and put it in a clear mayo jar filled with a little brake fluid. Once you see no bubbles, you are good to move onto the next brake. I'll see if I can locate a link.
http://www.stoptech.com/whitepapers/...rakesright.htm
Synopsis:
"Bleeding Process
1. Begin at the corner furthest from the driver and proceed in order toward the driver. (Right rear, left rear, right front, left front.) While the actual sequence is not critical to the bleed performance it is easy to remember the sequence as the farthest to the closest. This will also allow the system to be bled in such a way as to minimize the amount of potential cross-contamination between the new and old fluid.
2. Locate the bleeder screw at the rear of the caliper body (or drum brake wheel cylinder.) Remove the rubber cap from the bleeder screw – and don’t lose it!
3. Place the box-end wrench over the bleeder screw. An offset wrench works best – since it allows the most room for movement.
4. Place one end of the clear plastic hose over the nipple of the bleeder screw....
...continued."
The "how-to" is located about half-way down the page.
Nope, I just bleed the brakes as normal. I don't mess with the ABS stuff. If he's a mechanic where you work, just ask him if you can't just bleed the brakes without touching that other stuff.
Thanks, I appreciate the help man.
