Unable to set negative camber?
The car is basically stock ('00 SS).
If this is the case, I guess I'll have to find a way to move the top strut mounts.
Have you hit or run over anything?
Did they check Camber sweep?
That would indicate a bent knuckle.
At stock ride height, one doesn't get a lot of camber, but I would think you could get it to zero, anyway.
Leave the tops alone. If you want more camber, slot the lower A-Arm attachment points about 1/8" in order to slide the lower out, more. Easier and a LOT safer ....
I have wanted to lower the car for some time. Not only to lower the CG, but mostly to remove ~48 square inches of air from underneath the car. Maybe it's time?
However, from the centerline of the car, the upper attaching points are slightly further apart than the lowers.
Another question I have, though, is further investigation of this topic implies that lowering all around results in a suboptimal rear LCA geometry. Some have advocated relocating the LCA mounts to recover this geometry. Any experience with this?
