Vibration...
Old Mar 21, 2005 | 12:15 PM
ZmyHPandrun's Avatar
Default Vibration...
These fu**ing rotors. Can I get someones advice on what rotors I should buy that wont warp!!!!??? I am sick of buying new rotors.
Kyle
2001 Camaro Z28
Old Mar 21, 2005 | 12:33 PM
Carlos01SS's Avatar
Your x-drilled slotted rotors are warped???
That sucks, I thought they were stronger than factory!!!
Old Mar 21, 2005 | 12:50 PM
Gregg_98TA's Avatar
I know how you feel. The only thing I have found is changing over to Corvette brakes. Though I am sure a good pad/rotor/fluid setup will do it, I just didn't want to take the effort. Plus, I figured in the long run the Corvette setup would be cheaper.
Old Mar 21, 2005 | 01:03 PM
trackbird's Avatar
The Brembo OEM rotors hold up extremely well.
Just remember not to make a stop from 100 mph as you park the car, and your rotors will last much longer. Try to cool the brakes for 1/2 mile or so before parking (don't go sliding into the parking lot sideways, grab the e-brake and run into work when you are late), if you park the car with the rotors at elevated temps, you can create a condition where they are likley to warp. The part of the rotor that's under the caliper will cool at a different rate than the rest of the rotor (the pads hold heat in and block cooling air), this can cause structural changes to the iron that can cause a warping condition (in some cases it can turn iron into "cementite" which is a hardened derivitave of cast iron which will wear at a different rate than the rest of the rotor, eventually causing a "warped" or uneven rotor faceing).
Try the Brembo OEM's. stranoparts.com or tirerack.com
