what srings?
Old Mar 27, 2005 | 09:39 PM
SMDLS1's Avatar
Default what srings?
I have koni sa shocks already and was wanting to change out my springs I have G2 springs and i think with high rear spring rate that the ride is a little rough the ride is not harsh because of the koni's. I want the smoothest riding lowering springs that i can find to replace my G2 springs. I only use the car as a daily driver and dont want it to lower more than 1.25". Thanks for the replies.
Old Mar 28, 2005 | 07:21 AM
SMDLS1's Avatar
any sugg?
Old Mar 28, 2005 | 08:39 AM
01 Red WS6's Avatar
maybe a pro kit. They have a softer spring rate
Old Mar 28, 2005 | 09:40 PM
SMDLS1's Avatar
thanks
Old Apr 2, 2005 | 05:09 PM
JasonWW's Avatar
Keep in mind that the lower you go, the stiffer the springs need to be to prevent bottoming.
The prokit is a 400/80-137lb set so it's not too stiff.
What are your shocks set to?
Tires make a big difference in ride. Maybe a softer side wall or lower pressure will take the hard edge off your ride quality. I knoe the stock GSC were good aweful stiff. No spring or shock would have helped with them.
